Project AvP by GoTaLL
October 6, 2005 | 17:52
Tags: #alien-vs-predator #avp #engraving #fatal1ty #gotall #star-wars #stencil
Project AvP by GoTaLL Top Panel
Top Panel
Project AvP by GoTaLL Top Panel Project AvP by GoTaLL Top Panel
Remember what I said about changing your mind? Well, I decided the AvP logo would look better at a 45 degree angle in the top right hand corner - it was too boring to put it square in the middle. With everything taped down securely, it was time to get started outlining.
Apologies for the blurry photos, but they are the only ones I have showing this step. As you can see, you start by tracing the outlines. Never attempt a block of colour from scratch (if you can forgive the pun!). Make sure you get all your outlines done at this point.
Logo filled in, and Mr Predator too.
Some time later, it's done.
